I’m on Pro version, but the app is unusable after update. Keep getting error messages when choosing masks. And the brush to select area to edit disappeared? How do I roll back to the previous version?
Hi,
If you are on android or apple you may be able to download the previous version.
Although it would be better if you can describe (or post screenshots) of your issues so we can fix them!
What error messages are you seeing?
What do you mean the brush to select the area has disappeared? You are clicking “Add a Mask” correct? What do you see? The brush is the first tool (far left) and is selected by default.
The masks error code 400 seems to be fixed after reinstalling the app. As for the brush tool, I tried using Brush and Object tools from the short cut list to highlight an area, and prompt AI that’s the only area I wanted to edit. But AI always change the areas that I didn’t instruct to edit. After some exploring, I found out if I use the Brush and Object tools from Quick action - replace, then they behave just like the older version. Have I mistaken their usage? I’d like to show you but the load image button here doesn’t work.
Glad you sorted out one of the issues.
Can you show me a screenshot of your prompt? (the input screen where you hit the generate button).
If you are hitting ‘generate’ and there is a mask attached to the prompt - the AI should not change anything outside the masked area.
Thanks!
