Adding upper cabinetry
I am trying to add a small upper glass cabinet on the right with floating shelves below. Trying to connect the small glass cabinets with a wooden valance.
I have used replace and nothing happens
Hi, What do you mean nothing happens?
Are you hitting generate? What happens when you hit generate?
What mask are you using?
Yes I hit generate. By nothing happens I mean the result generated is the same as the picture submitted.
I highlighted the area I want to add the lighted cabinets to. And and my prompt is upper glass door black cabinets, since you can’t say add
Can you take screenshots of your mask and results and maybe post the image so we can try?
