How do I get a TV in the center of a oicture?
Tried TV in center, TV in middle, center TV, etc, but the app will always place the TV on the side along a wall.
Can you post your image? If so I’ll show you.
The first thing to try would be just the prompt, ie “middle of room” “left wall” “centered above fireplace” - you can try a few times and usually get the right result. However sometimes the AI can be very opinionated about where it should go and not follow the guidance very well.
In this case I usually use a “mask” to tell the AI exactly where to put it. Click the little plus button in the lower left and click “Add a Mask”, then use the brush tool to paint the general area of photo you want the TV added (or any other change). Don’t be stingy as add a TV will add shadows and change lighting of objects around so give it plenty of room. And then you can try a few different prompts - maybe just “Add a TV” or you can still try the directions “Add a TV in the center”
By adding a mask you are limiting the area that the AI is allowed to change so you’re basically forcing it to add it in that location. Also works for tricky removes and things like that.
