I am having trouble using reskin to make the garage door black. I can do it in the remodel tool but it changes the rest of the house too. Any suggestions?
Thanks!
Thanks!
Hi Andrea!
This one was a bit tricky. I think the shadows are confusing the AI.
Make sure you make the mask BIG. Don’t try to just include the garage door. If you miss a few pixels the AI can see the existing garage door color. See my example.
Then it may require a few attempts with different prompts.
It took me a few tries.
I ended up with “black garage door, dark tinted windows, dark”
Another good trick is once you get a satisfactory or even half decent image, save it and then repeat the process from the beginning with your new image. Once you have an image without shadows on the garage door it tends to produce better results much more easily.
