How do i edit a set of images?
Hey there,
i do have a set of interior images (hallway, bedroom, kitchen, livingroom,… all connected by the hallway with open doors. How can i be sure to have the same look/interior in all images?
Like you can see the living room through a door of the hallway, then the livingroom foto itself should look similar.
best wishes
arne
I find the best way to produce the same style over an assortment of images is to either have a very descriptive prompt (if you are using custom prompt).
Or if you find an image you love, just save that image and use it as the style image for the other images.
To me the outcome, even with style image is different from multiple angles. Multi-Room or Multi Angle solution seems to be a very difficult task for generative AI.
