Hi, new here. I just got a new couch and I want to see what kinds of end tables and coffee table would look good with it. How do I keep the couch and just add side tables? I’m adding natural language in the editor custom mode, but it changes the couch and doesn’t add the tables… fidelity is on high. Thanks!
you don’t want to use the remodel tool for this, because its designed to match the current room layout. turning of the fidelity makes it match the existing room layout even more closely.
you want to use the replace to to insert new tables into the image.
specify the area in the image you want to place the table. The AI is only allowed to change the area of the image you specify, and then provide a prompt. Watch some of our youtube tutorials for an example.
