Looking to do a full remodel of living room. Cream/off-white paint on walls, remove crown molding, add hardwood floors, keep fireplace but replace mantle with natural wood. Add full wall of white built in shelving where the TV is. Keep gray sectional but replace corner chair.
Hi Erica,
This was a really fun one!
Here are a couple of my attempts:
You can repeat my process by following the video here:
Hopefully this helps you build and explore your vision of this room.
One of the things I would note is that all the high-end pictures are very well lit. Lighting will make a huge difference in this room, so you’ll probably need to figure out how to install canned lights.
Thanks!
