The app paints the desk, which I do not want. I only want to paint the arched cabinet. Can you help me choose a color for it that works with the space?
Hi Kris,
Are you using the paint tool? You can determine exactly what is painted in the masking process.
Check this video: https://www.youtube.com/watch?v=60GukrC0UhE
If you are using an auto mask that is also masking the desk, just use the eraser tool to remove it from the mask.
You can also just try the reskin tool if you’d like color suggestions as it will reskin the cabinet and pick a color for you. The masking process on the reskin tool doesn’t need to be accurate.
