Just starting to use the app and was wondering if there’s any way to give it more specific instructions? For example, measurements when doing remodels, such as knocking out a wall to extend a kitchen…
Hello! In the Tools section. You can easily eliminate certain things. And try with trial and error. Example wall markings. And place remove. And you see how it turns out. Greetings.
You can use the replace tool to make edits like that, but make sure to not give it instructions as it doesn’t understand instructions.
Instead just describe the image you want to see. For example you can remove the wall and replace it with a “large kitchen”
