I am trying to render a stacked washer and dryer in a laundry room. The AI keeps generating images with multiple pairs of washers and dryers instead of just one set. How can I adjust this? I am using the replace tool.
Hi,
When doing a replace, the two variables I play with the most is the masking size and the prompt. Also remember, you don’t have to do everything in 1 step. If you find a great result but there is something you don’t like (like a duplicate washer) You can go back and remove the second one with the replace tool.
My guess would be that there is something you aren’t covering with the mask which leads the AI to believe there should be two things there and its making two, but hard to say without seeing the images and mask.
